Chinamandrift wrote:has anyone tried this on the CA18 head ?.....im preparing to build a ca18det ....the head is off ....and im going to order internal parts ....i thought it be interesting ........
if u tried this .....what size valves ?? and how was the piston clearance?
Have you ever built a CA before and if so, what kind of power have you extracted from it. The reason I ask this is, whilst monitoring the forum members' requests, I see you inquiring about all the good stuff for a CA, but I don't see you mentioning your goals or even how you plan on controlling it and for what purpose will you be needing such an engine. Is it for bragging rights?
There are many people here who yearn for that famous 9000rpm claim, but is not prepared to pay the price to get there and get there while being able to use that much rpm effectively. I'm not trying to bust your balls dude, but I really think you should probably just get a CA18DET and learn how to extract good/clean power from it before you go flickin' dollars into something that will be experimental. You have to crawl before you walk and it's very hard to skate uphill. Good luck on your quest, though!
P.S. You don't really need bigger valves in this head if you got a really hot valve train set-up (ie, solid lifters, heavy duty valve springs, hot cams, serious porting and massive machine work to the head); I have a fully built CA that was built over 4 years ago and will more than likely let you rev to 10,000rpm, but I'm in no rush to use because there's still alot to learn before I risk experimenting on an engine that cost me nearly $6000 between the head and the block alone.
Dee
