DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sat May 31, 2003 6:05 am
I thought oil pressure varies little throughout the engine. If you open up the bearing gap somewhere, the oil pressure will drop everywhere. I don't think you can swap bearings like that, since they're all match-machined. If you bolt the bearings down without the camshafts, run your finger along the inner bore and feel for any ridges at the seam. Put the camshafts in and use some plastiguage on all bearings to check clearances, in addition to comparing inside and outside measurements. Also, lube it all up and make sure the camshafts rotate freely without any binding. The first test, just feeling the inner bore, will probably prevent further investigation.
