Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Mon Jun 30, 2008 11:51 am
The "Viscous Fan Clutch" is a circular, finned aluminum "pancake" that is mounted to the back of the main plastic radiator fan, connecting this plastic fan to the fan belt pulley on the engine. When it's working properly, a built-in thermostat forces it to make a strong mechanical connection between the fan and the pulley whenever the air flowing through the radiator gets hot enough. This solid connection allows the pulley to spin the fan at full engine speed, thereby providing maximum cooling.
During cooler weather, this fan clutch loosens the mechanical connection, allowing the plastic fan to "freewheel" at a much slower speed.
The fan clutch tends to wear out over time, resulting in the plastic fan never spinning at full engine speed. This reduces the fan's ability to cool the engine, particularly during slow-speed driving (when little air is forced through the radiator due to vehicle speed alone).
When the fan clutch is working properly, the engine will make a louder roaring noise in hot weather, due to the fan always spinning at full engine speed. Another test is to shut a warmed-up engine off during hot weather and immediately attempt to spin the fan with your hand - If the fan clutch is doing its job, it will be difficult to spin the fan, which will immediately come to a complete stop. If the fan spins easily and doesn't stop rotating immediately, it means that your fan clutch is no longer making a solid mechanical connection between the fan and the fan belt pulley, and needs to be replaced.
