480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sat Dec 29, 2007 6:32 am
Go up to your local parts store and buy a bottle of radiator flush.
First, you want to drain all your coolant out of your system. Since your coolant system is already trashed, you should first flush it out with just water to get the big stuff out. Fill it back up with water, and let it run for 10-20 min until it gets hot. Then drain it again. After this time, use the bottle of radiator flush, and follow the directions on the back of the bottle. After you do that, flush it with water at least one more time.
As a side note, bleeding all the air out of your system can be a pain in the ***. Make sure you jack the front of your car wayy up, so the radiator cap is the highest point on the engine. Then fill your radiator with the bleeder screw open until a steady stream of water/coolant shoots out of that hole. Then, start your car and leave your car running for 5 min, or until the thermostat opens with the radiator cap off. Just keep an eye on your water temp gage to make sure you got the air out of the system.
