over heating
drag
Car: nissan 240sx 1990
I have a 1990 240sx, its always overheating, i already change the fan, water pump, the hoses radiator, i took out the termostat kos its hot in my place. but the temperature keeps going up. yesterday one of my radiator hose burst. m thinking ders pressure. not suppose to have that, Ive already tried the super flush, but its the same, but i dont have any leak. what is the problem n what can i do? do i need to open the engine? i dont wanna do that. i dont have the experience. help me pls. its been a long time m doing this sht, m tired of it. thanks
neo
All cooling systems are under pressure.
Use an OEM cap (for proper pressure regulation).Use an OEM thermostat (rated at proper temperature).
A radiator cap rated at the wrong specification will put pressure on the weakest link in the system or fail to properly cool the engine.
Put your thermostat back. Drop it in a pot of boiling water with a thermometer to test its functionality to make sure it opens at the correct temperature, or just buy a new one. Theyre practically free.
Also, in hot weather, use 70% distilled water (NO TAP WATER!) and 30% Nissan green coolant.
drag
m thinking that thers a clog inside my engine, or i think u call it water jaket, its like a tunnel were the water runs. and in our island, everyone takes of the termostat, they say we dont need it here, kos its very hot here, where under the equator, well close by. is it ok if i just transfer the radiator from a auto 240 to a manual 240?
Sorry, I wish I could answer that question. Hopefully later today a moderator will move this to the correct forum. Someone else who knows more about 240s can give you a better answer.
