sleepyRPS13 »
https://forums.nicoclub.com/sleepyrps13-u4928.html
Sun Apr 09, 2006 8:21 pm
does it overheat from idle on traffic or cruising or is it period of time?
im thinking that you installed & inspected everything properly. thinking you did it yourself?
ok...overheating is usually 3 things: coolant level, heat transfer, & coolant circulation.
1. coolant mixture/ coolant level ( it should be pressure test ) / air in the system
2.fans heat trasnfer like sitting on traffic
3.restriction circulation on radiator/ stuck thermostat/ bad pump
thats all...
unless you have a hot spot somewhere on the motor. duum dum dum. :-0 (shocked face )
