Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Tue Apr 06, 2010 5:29 am
A lot of people that try the electric fan go back to the stock one for that very reason as the stock fan can move nearly twice the air any electric can, but at this time of year it shouldn't be an issue. There is no way you should need to turn your heat on to compensate for the cooling system effectiveness.
Putting an FMIC in front of the main rad, A/C condenser and oil cooler can't help either as that really impedes the air flow.
All the air is out of your system? Your thermostat is good? If you take the rad cap off and watch the coolant, do you see any bubbles going by?
At work we use a vacuum unit to draw the coolant into the engine which ensures there is no air trapped in the system causing low amount of flow. I plan on doing a writeup on a simple home made system to accomplish this as many engines are difficult to evacuate the air.
