over heating problem
300zxtt93
Ok SO i have a 1993 300zx tt swaped. We were fine and then the other day the water pump went bad. . . so we replaced the water pump and the thermo ( not easy to do) and then we thought it was fine and it started to overheat again now with no leaks. . .so I am trying to figure out what the hell is wrong. If you have any ideas please post up!!!
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
No leaks with a good water pump and thermo = Blown head gasket. Do a compression check on all six cylinders.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you get all the air out of the system? still running the mechanical fan? belts tight?
DustinZ
evildky is right check for air leaks check the fan belt and maybe even check that the radiator is not clogged.
300zxtt93
Ok well I have checked all the lines.. .no leaks... I have checked the belts they are tight, the rad is brand new. . so I am unsure where to go from here. Is the head gasket a hard thing to do on this motor ?? Please give me some heads up. . thakns
evildky
06 Nissan 350Z GT
headgasket's are a pain, you sure you got a good thermostat? I've had dead ones brand new before. if your blow a headgasket you tend to either get coolant in your oil (check the dipstick if it looks foamy and whilte you got a problem) or you blow exhaust through the coolant passages and out the overflow canister, or in some more mild cases you'll only get a little coolant into your combustion chambers and you'l get lots of white smoke usually after startup
