Over Heating problem for my KA
d1_king
Car: 240sx
ok i have a KA24DE and the compresion is up.it haska24e pistons,Port and Polishedoversized valves and springs
it overheats for some reason and i cant find the problem.i checked cooleint and everything. it seemed right.
480sx
Car: 1996 Pearl White 240sx
Give us some more information.
When did this problem start, was it an onset thing that gradually kept getting worse, or did it start after you did some work to your engine?
Is it running just a little hotter than usual or does the needle keep going over to the edge of the gage?
How many miles on your engine, have you done anything like replacing the water pump, radiator, or thermostat?
Have you checked your coolant level, do you have any leaks?
Im sure there are more questions to be asked but i cant think of anymore at the moment, just give us as much information as you possibly can.
d1_king
Car: 240sx
the engine is rebuild and it has a koyo radiator and a flexlight fan.when you warm up the car it stays alittle above the middle range and when you drive it it starts to get close to the H mark.i dont see any leaks and the fluid level is fine.
480sx
You probably need to bleed the air out of your coolant.
