Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Mon Apr 23, 2007 3:58 pm
Sounds like the water pump might be going out. Or you have blockage in the water system.
Be sure to check the A/C Condenser for blockage, and make sure the electric fan is working in the A/C mode.
Also, make sure the gasketing around the radiator is intact. If it is missing, the car can loos a lot of airflow through the radiator.
Overheating will melt the knock sensors, and they are $1,200.00 to replace. Don't drive it hot at ALL!
