shockload »
https://forums.nicoclub.com/shockload-u28825.html
Sun Jul 02, 2006 6:47 pm
a few days ago i decided my car was getting a little too hot on the highway so i dumped in half a bottle of water wetter and then later while driving my temp kept shooting all the way up and wouldnt cool down for maybe another 5- 10 minutes, it did this maybe 3 times. the next morning i changed the thermostat and put the same coolant back in bled the system and drove it around and the same ****. the t-stat i removed was a 180 deg the one i installed was a 170 deg. the only way i could get the car to cool down would be to leave the fans off and feel the radiator untill the thermostat was open and it got hot then turn the fans on. today i ran the wire to my fans to the original switch in the bottom radiator hose and also changed the coolant and added 1/3 green stuff and the rest water with 1/2 bottle of water wetter. the fans only coem on when the radiator gets hot like they are supposed to now but it still gets at least one instance of going up to almost h and back to normal in a 5-10 mile drive. the real question is , does water wetter in the system make my thermostat slow to open because i never experienced this type of behavior before. i have tried everything thing on the piece so far and tested for leaks, no combustion gas enters cooling system ect... anyone ever have bad outcoem from using water wetter?
