T88lexus »
https://forums.nicoclub.com/t88lexus-u19328.html
Sun Sep 26, 2004 12:01 pm
check the both radiator hose.. when the temp start go high.. make sure that you dont feel the bubble.. which is air in the water. ---- mostly headgasketif the water temp is dramatically different than upper and lower hose.. it is thermostat.
I have seen couple of the water temp sender( the one to the gauge go bad ) which the gauge reads wierd.. going up ,, comming down..
make sure there is no air in the water system.. if there is any air in system.. sometime. the sensor will read the air temp in the system rather than reading water temp, which will make temp gauge to go crazy. if there is a air bleed it.
