87Sleeper »
https://forums.nicoclub.com/87sleeper-u81947.html
Sat Nov 24, 2007 9:08 am
Check the coolant sensors that send info to the dash and the ecu , maybe their messed up. My water temp gauge on my dash almost works like a vacuum gauge, when I give it gas it goes down a little, when I let off it comes back up, But i think my thermostat is always a little open, because I took my clutch fan off and it never overheats on me. Also I have a new water pump. Also make sure your overflow tank is allowing excess coolant to escape from your radiator into the over flow, if this is clogged you sealed your system and teps will shoot sky high (i.e. experience)
