Flyingdog »
https://forums.nicoclub.com/flyingdog-u143708.html
Mon Jan 25, 2010 10:59 am
i always check my sensor against the molson clock, just south of the Burrard St bridge. my qX4 reads about 2 degrees warmer ....
that was unil i did a trouble diagnosis on the a/c. i didn't find any problems, but it does ask if there is a temperature discepency and there s an adjustment for it. i idn't actually adjust it, but i have noticed since then that the tempurature is pretty spot on now.
the only other thing i can recommend is that the weather network and radio usually quote the airport temp, not necessarily the downtown temp. downtown will usually be a little warmer. i'm not sure where the molson locks measure from
