Outside temperature gauge 3 lines after battery drain
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
dardack
Car: ???
I was working on the ball joint replacement and left the car in the on position to rotate wheel and ofc it drained the battery. I jumped started it, but now the outside temperature gauge is showing 3 dashes/lines instead of the degrees outside. It's been a couple days, still no change. Can't find anything in manual, anyone have ideas?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
dardack wrote:
Sat Jun 19, 2021 10:01 am
Try disconnecting the battery for 10 seconds to reset the cluster. Weird things happen when the voltage drops below 8.5V, the cluster processor may be "off in the weeds".
Return to “Versa Technical Discussions”
