I haven't looked but there should be existing holes in the firewall for cables running from the engine bay to the cabin.fortinjf wrote:Is there an easy place where I could pass the wire from inside the cabin to the outside?
According to the published specs (and also the physical reality of my own 2010 Rogue SL), you should already have an external temperature display. Its one of the things you cycle through on the drivers display. I didn't think it was an option.fortinjf wrote:I would like to install an outside temperature display inside my Rogue. Is there an easy place where I could pass the wire from inside the cabin to the outside? Also, according to you what would be the best place to hide it outside: front/back? inside bumper? Thanks for the help.
All icons DO light up. Did you try to read the service manual ? Page 32Leo2005 wrote:If you buy oem therm sensor and speedometer from sl premium pckg. you will get oem thermometer. I'm not sure if it will work with regular speedometer (not from premium) but there's icons that doesn't lite up such as mpg and F. The wires already installed behind the front bumper. If you still want to install aftermarket thermometer then maybe this would be the best spot for you.
what-are-these-wires-for-behind-the-gri ... re%20these
