output shaft
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
to make a long story short, i need a new output shaft from the differential. I have a 180SX VLSD (5 bolt design). is another 180SX output shaft the only shaft i can use or perhaps would one from a 96 J30 or 300ZX work? or better yet, does anyone have a spare 180SX output shaft I could buy?
hek1620
Car: '89 240sx
well u need two output shafts to make it work. and 300zx's won't work, they're too long. im on the same mission. i have a diff from a 300zx, but i need the shafts to make it work.
S14Life
the lsd is in my car and has been for a few months. the bolts on the driver side connecting the axle to the output shaft came loose and i drove it with it llike that (unknowingly) and so now the bolt holes are all egg shaped. so yeah, i may just call the importer i got the lsd from~
Blown240sx
Car: 1996 240sx
Why not just go to a shop that can make you an adapter or fitting to work with your existing shaft? Might be same price as buying a new drive shaft, or maybe cheaper.
S14Life
i dont need a new drive shaft.. i need a new output shaft from the differential..
