Outer tie rod replaced.
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Driver side repaired,but steering wheel doesn't self center.Seems to wanna pull to the right also.Didn't do alignement that comes Fri Are there weights or something that have to be balanced?Pull to match slack on driver side?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
it's your alignment. Once you have that done your return to center will be 100% improved. Just went through it this week and replaced rack and tie rods.
black g50
Meant to say it pulls to right over bumps.
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
Just like paranoidjack said, its your alignment. That "pull" you get over bumps is called bumpsteer and is from your alignment being out of whack.
q45touring
Car: 1999 Infiniti Q45t
2000 Infiniti I30t
2002 Honda Accord Coupe SE
If you didn't put the tie-rod back on with exactly the same amount of turns, that would definitely cause some issues. Make sure you do both outer tie-rods, as it would be beneficial since you are spending money on an alignment.
N/A Q45
Car: 94 Q45
q45touring wrote:If you didn't put the tie-rod back on with exactly the same amount of turns, that would definitely cause some issues. Make sure you do both outer tie-rods, as it would be beneficial since you are spending money on an alignment.
I would disagree some what as maybe it wasn't in the right spot in the first place.
Just get a alignment like everyone's saying-
DrewQ45
Car: 1990 Infiniti Q45
When I changed mine, I replaced inner and outer - both sides. Also replaced cracked rubber tie rods with JWT solid adjustables. Front end was tighter than a virgin's.
OwnerCS
+1 for an alignment. Regardless of how you try to sight align it, it will drive crazy until properly aligned on a good front end machine.
black g50
Completed last week,sorry for late update.
IThaJ0kaI
OwnerCS wrote:+1 for an alignment. Regardless of how you try to sight align it, it will drive crazy until properly aligned on a good front end machine.
While I partially agree if you have only sight aligned a car a few times. There are a lot of us, myself being one of them, that sight aline cars. I get my car aligned to be positive afterward, but 9/10 I get everything within spec and usually pretty even on the camber specs. This is partially because I was a broke 16 year old trying to 0 budget build everything I owned, lol!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Toe being out of alignment does not cause pull! The steering wheel maybe off center though.
