I am install a set of Moog outer tie rod ends on my s14, I can't seen to get the lock nut loose, is there some trick to it, I put pentrating spray twice in the last two days. Is the nut threaded the other direction?
I don't have a 22mm wrench so I am using two creset wrenches, one on the nut and one on the inner tie rod end, this should be an easy job.
I would appreciate any advice,
thanks
