out of the 365 days in a yr, how many of them does your rb run good?
MOB240
Car: 1995 nissan 240sx
i was just wondering how hard it is to maintain the rb's. is it just like any other turbo'd engine? or does it tend to break down/act up more?
Shocker
Car: 89 240sxHB rb26/30
Everyday last year, only had two issues. Coolant line exploding, and fried my fan relays, other than that, all good.
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
I have had my car for a little over 2.5 years, and have never had any problems with it that I didn't cause myself (Didn't get the coil pack plugs in tight, and it ran like a$$, and I was running regular gas, instead of the hi-oc and had some knocking). Only time it was down was while I was in the states the begining of May, and a friend took care of it for me. So, runs like a champ every day.
It's been a fantastic engine and seems like it still has lots of life left in her.
1990 Nissan Laurel Club S turbo, RB20DET.
MOB240
yea but how much boost are you running and how often did you beat on it? lol those two things really tear your car up if you dont have the right parts!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
MOB240 wrote:yea but how much boost are you running and how often did you beat on it? lol those two things really tear your car up if you dont have the right parts!
When I have my boost controller turned on, I have it set between .85 bar and .90 bar. I don't "beat" on it perse, but I accelerate quickly quite abit, drive hard quite regularly, and when I go to get on the highway, I romp on it alot. But I also do my preventive maintence. Oil every 5,000k. Just did my transmission and rear diff fluids last week.
The car has over 125,000 kilos on it.
Carl H
i daily drive mine, been running since last june.was down for a month or so while i replaced a clutch and resealed the motor but has been fine since.
Shocker
11psi all last year, at 277rwhp. Daily driven.
240z4u
Car: '95 Nissan 240SX
I am very fortunate to have a company car right now. Before that, I drove it 365... rain snow sleet.. you name it.
Great driving motor. 14psi with a garbage tune. Ill be going back to having it as my daily within the next few months. Can't say I am disappointed to have to use it as my daily again. I beat the crap out of my car btw.
I would swap my car again in a second. Sometimes I wish I would have gone turbo KA for some reason.. parts are easier to find (this has never been a problem).
evan
Ramius83
Car: 1995 240sx SE
I drive mine every day. It has been running since April of 2005. No problems what-so-ever. I use to have an ever so slightly creeping up temp gauge, but that was due to one of my Flex-a-lite fans going bad. And when I first completed the swap, the new water pump leaked. Come to find out I was given one for an RB25. So I pulled out the one bolt that was leaking, shot a ton of Ultra-grey in there, and put the bolt back in. Fine and dandy ever since. This prevented me from pulling the timing belt off. I still have the same SPEC Stage 2 clutch in the RB26 since Day 1. It has over 45+ passes down the 1/4 mile, with launches at 5000 RPMS.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
10psi 275 everyday for 2 1/2 years with the exception of a couple days that i poked at it
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
4 1/2 years and going strong only problems ive had are **** i caused like washing the engine and a alt taking a ****.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
mine's been good to me as well. granted i replaced everything I could besides the oil pump before the swap. Had a turbo take a dump on me, but I probably should not run the stock ones every day at 14psi :-)keep the oil changed every 2500 miles, good oil and filter, have proper cooling and all should be well unless you get a devil engine.
