Looneybomber wrote:4cefed wrote:I'm guessing electronic throttle? Remember when we had these old fashion cable thingies that attached the driver to the throttle plate?
Why is it when you remove the cable to the throttle body and replace it with a bunch of electrical stuff, it's called "drive by wire". Shouldn't having a cable hooked up be "drive by wire"?
Mechanical throttles use cables.
Electronic throttles use wires.
"[something] by wire" is an old aircraft term. Which also distinguished electronic wires from mechanical cables.
D Tune Performance wrote:Stop letting them tag you along, slap them in the head and tell them to give you a new Throttle body.
Agreed. Tell the dealer to try replacing either the throttlebody module itself or the pedal sending unit. One of them is probably to blame.
