If you have mechanical knowledge, you can probably change your timing chain guides yourself.
This will still cost you in the neighbourhood of $400-$500 for the parts.Slightly used ones here....
zerothread/225960 for $250, with an oil pump too!
Your mechanic is an idiot, only looking to fleece you of your money, by doing expensive yet "easy" work.
Fuel pump and Fuel Pump Control Unit (FPCU) are probably the cause of your Q not starting at the moment. Try looking through the classifieds section for these parts, or try member "PopPop" as he seems to have a lot of parts.See here
zerothread/162550
Send him an email at
[email protected], and see how much he can do the FP and FPCU for you.Good luck!
