thanx all for the info and comparisons much appreciated
all i can say is that a very very good CA18 here i australia has never gone past 310 rear wheels kws. and that particular one was a stroked tomei version
ca18 powered cars here running mid to high 10 second quarter mile are only in the 230 to 260 rear wheel KW range.
the engine is running fine and i certainly wont be changing dyno tuners
we are very happy with results.
the other thing to notice is the rpm on that graph. we have not yet used any of the rpm capabilities of this engine yet.
also in case some of you dont already know our old engine only made 180 rear wheels KWs and it was able to run a 11.9 @115 MPH quarter.
the weight of the car without driver would be around 1200 Kg. it has a full interior and is not lightened in any way or is it going to be.
we have been to the dyno many times with our own cars even engine dyno with one of our engines. so we are no stranger to them.
we will run on goodrich drag radials as well as our slicks but primarily will be on street tyres.
60mm IC piping
i also dont like comparing apples with oranges. every dyno is different from one tuner with same model/type of dyno gave a 20 KW higher reading on exactly the same day same car within a couple of hours..
if the weather stays ok i will be running it this weekend .
