OUCH
AkademikONE
Me and my friend were drifting around in this one industrial are around here. It was around 3am. Long story short, we hit a curb. We want to know what parts we need to replace, and if anyone in So Cal is selling them. Here are pics of the damage. I just need names of the parts that were damaged so we can fix it.
Right front wheel
Right rear wheel
Also, if anyone can help us fix it, we'll provide food and drinks, and some money. Some smokes too if you smoke. Thanks.
240marcuSX
Car: E34 525i
E46 M3
youll need a new tension control rod, and front lower control arm, youll need new endlinks if not an entire new sway bar, rear lower control arm, and one hell of an alignment.
and it wouldnt surprise me if you have frame damage, how twisted those pieces look. not good news.
Exar-Kun
Car: 2005 350Z
and probalby a new T/C bracket...and Tie rod (and end!)-Chet
Dirtylou
Car: 1991 Nissan 240SX RMS13
Sheesh...that really sucks. It looks like you need just about everything linked your spindles.
AkademikONE
I was told these things from a friend
front: lower control arm, TC rod, bushings endlink
rear: lower control arm
what else?
4felix20
Car: Emerald Blue S14
i'm 100 percent positive in the rear, it's just the lower control arm. not too expensive, but definitely not cheap. i did the the same thing to my right rear once plus even more damage than that and replaced it all my self. to replace the lower control arm is pretty simple, you're gonna need a ball joint seperator though...sometimes called 'pickle forks'. they're about 10$ at any well supplied auto store. i can't tell you exactly how to do it though, i'd bent mine up like that over 3 years ago. i used a chilton's manual and didn't really have any problems.
i'm not sure about the damage in front...
4felix20
damn. you guys post fast...
240marcuSX
Car: E34 525i
E46 M3
if you want to buy my stock sway bar, and tc rods, ill send them across the country for you, but you can get them easier locally probably.
240marcuSX
Car: E34 525i
E46 M3
take a picture of both the front and rear from the side from above and below the brakes, but i think the list we've given you is pretty close so far.
but man, you never know, you might want to take out your damper assemblies too, that front one looks like it has alot of stress on either the top or bottom mounts... all kinds of stuff could be bent out of shape.
AkademikONE
front:
right front LCAfront TC rodbushings endlinktie rod and tie rod endsway bar
rear:right LCA
anything else guys?
240slidekat
Car: 240sx, 280z, gsxr1000, m3
oh and dont forget to add: not to let simoun drive my car! =)
240slidekat
oh you should hit up the junk yards...cheap parts
AkademikONE
Yea, I'm hitting them up on Monday.
240marcuSX
Car: E34 525i
E46 M3
you might not need another sway, but it couldnt hurt to replace it. and your list seems all-inclusive, at least that i can tell by the photos posted.
AkademikONE
People are going to sell me:
front TC rodtie rods w/ endlinks
All I need now are LCA's and the sway bar.
Anand
Car: 95 Nissan 240SX
the LCA's are going to be quite a bit of $$ unless you get stock used ones..
AkademikONE
Yea, gonna hit up the junkyard for those.
240slidekat
i was just at the junk yard today they have 2-3 240s overthere so check it out. i went to the one in santa paula. not too far. off the 126
Bio_Hazard
Car: a crushed 1990 240sx
you might have to rplace the stearing link, when i did that to my car i had to replace it.
