other than smell, how to tell if cat is bad?
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
so other than the smell, how do you tell if your cat is bad? my car smells funny, sometimes like rotton eggs, but more often it just smell not right, like really strong gas fumes or something, (not really sure how to explain it) i used the search, but non of the answers really seemd to help me figure out what was wrong.
my car is a stock 1992 240sx 5spd
it doesn't seem to be having any problems in the performace part and it idles just fine.
*edit*
the other smell kind of reminds me of bleach if that helps.
navysnail
did it pass emmisions smelling like that
ceniack
240kid wrote:did it pass emmisions smelling like that
i live in oklahoma, we dont' have smog tests
navysnail
ahh. my auto teacher has said that some old cars smell like rotten eggs, it may just be because of the age. change it if it makes you feel better, or you could just replace it with a test pipe since you dont have emmisions.
NISTECH
The rotten egg smell would be cat the other odor may be the reason for the cat going bad. to rich or to lean of mixture will take a cat out pretty quickly.
Since your in oklahoma maybe you ran over a possom and it is cooking on your exhaust. Get the engine good and hot ran it at about 2000 rpm for 10 mins stirring occasionally till it becomes crisp on the outside after ten mins you should ba able to peirce it with a fork. Its usually done when you can pull the fork out with out the juices sticking to the fork. Then serve it with a nice vinager sauce.
Sorry I couldnt resist!! It was the whole oklahoma thing.
Seriously though you may have a rich fuel condition going on. Do some checks on the Maf and if possible a voltage check on your O2 see if its locked above or below .5v. It should fluctuate above and below it and not be stuck at one side or the other.
SmithSR
Car: 240sx
I've GOT to start reading more of these threads....
:D
ceniack
NISTECH wrote:Seriously though you may have a rich fuel condition going on. Do some checks on the Maf and if possible a voltage check on your O2 see if its locked above or below .5v. It should fluctuate above and below it and not be stuck at one side or the other.
how would i got about checking the Maf, and where do i check the O2 sensor at (i already have a Digital multi-meter, just need to know where to stick the little red and black probes)
NISTECH
http://www.nissaninfiniticlub....26515
NISTECH
On the maf put your black lead of your multimeter to the neg batt cable and use your red lead to check voltage at the 3 wires on your airflow meter you prope the back side of the connector while its plugged in a pin or paper clip works well. one wire should be battery voltage ,one wire should be 0v and one wire will be between 1.3 and 1.5 volts at idle. On the 0 volts wire it should be no more then .02v.
Touchdown038
Car: Computers, cars, sports
Mmmm.... opossum.
ceniack
NISTECH wrote:http://www.nissaninfiniticlub....26515
where is the ECU located (is that the sliver looking box in the center console?) sorry to be such a newb, i just got this car a little over a week ago
NISTECH
http://www.nissaninfiniticlub....26523
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
Can't say that I've ever had a possum. Hmmm.....might have to run over one so I can try it out. So you say 2000 rpm for 10 minutes, but if it's especially warm out, will that cooking time be reduced? Also if I kick it up a notch and run it at 2500, will that be reduced to 7 minute??
ceniack
thanks for the info...
and about the possum, you actually see more armadillos around here dead on the side of the road (and in fact, i have only seen a live armadillo once when i was a kid) and besides, they taste better, just hit it, pop open the hood, lay it on your header, and grill away. tastes like chicken
rousie13
I don't think I've ever seen an Armadillo, and this is why I love NICO so much.
180fan
Car: 89 fastback
my buddy Josh from NJ had fireballs flying out his tailpipe when the cat had a hole in the center lol
NISTECH
180fan wrote:my buddy Josh from NJ had fireballs flying out his tailpipe when the cat had a hole in the center lol
SWEET!!:ylsuper
