Other radiators
originalsin
ok so i was reading on 240sx forums that some guy used a radiator from some turbo volvo and it fit near perfectly, only problem is it was with a SR setup, so anyone know of any radiators from other cars that are bigger than the stock one and thatll work with the ca or ka???
RMiller
Car: BBQing
Don't know, but I wouldn't think so without at least some custom work. You could probably find quite a few that would work though. Just need to make the bottom plate fit possibly by simply drilling 2 holes, possibly by adding material and drilling holes, then fab up some brackets to hold it in. I'm assuming most radiators are secured similarly to those in 240s. Take some measurements of the stock radiator, then head over to a pick-a-part.
Jezz_s13
Car: Sil80 Track Car
The Koyos are only $330, the KA and CA are basically the same AFAIK.
originalsin
i know they are pretty much the same, and when ur working part time and only making like $100 a week and trying to pay insurance $330 isent cheap lol
91rs13
Car: Nismo 350Z
Datsun 510
Dodge Ram 1500
S14 KA Radiator fits.
http://www.radiatorbarn.com 2 Row all metal radiator --$130.97 shipped.
DJ
rico05
Car: 1992 RMS13 w/ CA18DET
Any KA radiator works. I have seen guys in JDM land and here use S130 radiators. They are bigger than KA radiators, bolt in, and are usually cheap.
Note: they are copper. So don't let it overheat. Ever.
rico05
91rs13 wrote:S14 KA Radiator fits.
DJ
Direct link to S13 (CA/KA) radiators from that site:http://www.radiatorbarn.com/a7...C2.4L
Sure, when a single row costs that much, why not just get a Koyo. And FYI: S14 and S13 use the same radiator.
wildacexxx
Car: 2002 Q45 nav sport
wats a s130?
81na ZX
Car: 81 280ZX, 69 Lotus Europa
78-83 280ZX
our radiators aren't that great though But theres a Chevy radiator that will fit, I'll have to look it up though.
rico05
wildacexxx wrote:wats a s130?
Damn man....learn your chassis codes! My friends and I rarely call cars by their name (cuz it makes us feel elitist I guess.....plus it confuses ricers )
81na ZX
And its alot easier to say s30 than 240z, 260z, and 280zs
wildacexxx
ok i know wat an s30 is, but wtf is a s130?
rico05
S30 = 240/260/280 Z (71-77) S130 = 280ZX (1978-83)Z31 = 300ZX (1984-89)Z32 = 300ZX/TT (1989-1996)Z33= 350Z (2003-)
History of the Z car in chassis codes.
81na ZX
wildacexxx wrote:ok i know wat an s30 is, but wtf is a s130?
Dude, I posted the answer right after your post :P
wildacexxx
i made a mistake reading it. i did not know s130 was a chassis code, i thought u were trying to say s30 and made a mistake. I was *cough* wrong *cough*
81na ZX
81na ZX wrote:But theres a Chevy radiator that will fit, I'll have to look it up though.
Its the "generic" 24x19 Chevy radiator (built by Griffin/be Cool/etc)$169 for the Summit version (SUM-380325)$189 for the Griffin version (GRI-1-26202-X) 1/8" thicker - many different trims that I have no idea what they mean.$299 for the Be Cool one :eek
1mns13
Car: Freedom and cars
Do you have any pictures with the summit one installed? Did they use the summit brackets? I think it will fit, but am cincerned about it's thickness. The 19" height can be dealt with, because I won't have the pins raising it off the lower rad support.
NeedCAforS13
Car: CA swapped S13 coupe
my s12 stock radiator is alot bigger than a KA radiator... might be something else to check out. CA18ET or CA20E radiator from a 200sx
Sean
rico05
Are the flanges on the correct side?
NeedCAforS13
exactly the same. I would be willing to guess that the radiator hoses are the same as well... I think I'm going to try using them rather than my hacked KA hoses I'm using now
Sean
cadet
Car: 89 s13 coupe
I'm gonna try running my stock ka24E one with twin 12" electric fans on a big shroud... should I expect to have overheating issues?I'm going to be running a stock ca.
knightrider
Car: black 90 240 coupe
im running a 2 row that came on my CA clip and a SR20 nismo low temp tstat(opens at 62C). my engine runs at 62-65 C and at the track it doesnt reach over 80 C. we will have to see what happens after i push the radiator back, install my FMIC behind the core support, and make up a custom shroud to work with the stock engine fan. but i doubt i will have any problems. and you shouldnt have any problems cadet, the CA came with the same radiator stock as the KA, but i would recommend running the stock engine fan, with a shroud, over running electric fans.
RMiller
Car: BBQing
knightrider wrote:im running a 2 row that came on my CA clip and a SR20 nismo low temp tstat(opens at 62C). my engine runs at 62-65 C and at the track it doesnt reach over 80 C. we will have to see what happens after i push the radiator back, install my FMIC behind the core support, and make up a custom shroud to work with the stock engine fan. but i doubt i will have any problems. and you shouldnt have any problems cadet, the CA came with the same radiator stock as the KA, but i would recommend running the stock engine fan, with a shroud, over running electric fans.
Why would you want the engine to run colder than it's supposed to? At 62 degrees my engine is still richened up for cold start. It runs best starting around 70. Stock thermostat opens at 82, hot type at 76.5 and cold type at 88. I bought the hot type and I never ever have cooling problems. I use a KA-E shroud w/ stock mechanical fan, 13psi on t28 and I idle at 78, after hard runs I'm under 90. It a track I'd probably be sitting right at 90 the whole time.
There's a reason Nissan chose the operating temp they did.
mikesim
the S14 KA rads are 2 core as well. $135 at radiator barn.
81na ZX
RMiller wrote:There's a reason Nissan chose the operating temp they did.
Actually theres two - emmissions and economy.
Notice one of thoes reasons are not power. Plain and simple, a cooler thermostat will give more power at the expense of emmissions and economy. If you're running into problem running a cooler thermostat, it means the problem isn't the thermostat...
