Other misc. parts for shock/strut/spring install?
slipnfall
Car: '06 D40
Hi there, I'm installing a set of AGX's and Tein s-tech's within the next two weeks. I'll also have a set of upper camber plates for the front(this is an S13 BTW), and rubber dust boots all around.
I'd like to know what other bushings, rubber pieces, etc, etc you guys would suggest I replace durring this install. First off, the front camber plates will take the place of the upper strut bearings, correct? Are there bump stops that will go on the AGX's(my stock ones)?
Now in the rear, I was thinking just a new OEM upper mount: I read somewhere that a solid rear mount(as is sold by Tein) will allow for more suspension travel(this was on a 200sx I believe). Is this true? Any big reason I should shell out $150+ for rear mounts?
Like I said there seem to be about 2-3 oddball rubber pieces in the rear, and I'm unsure of their purpose. I assume one of them is a bump stop, and the other the upper mount? NISMO makes replacements for these, and they aren't too expensive($10-20).
Thanks for any suggestions you can make. I know this a newb-ish post, but I would rather replace all those wear items, while I'm 'in there'.
Cheers,-Jamie
slipnfall
Car: '06 D40
No one? I know there are plenty of people out there who have done a strut/shock install: what parts did you realize you should replace when you had it apart?
babowc
Car: 240sx
a bit old post, but anyone who knows, please chime in!
also, slipnfall, what eles have you bought rather than the tein and the agxs?im considering that combo, but i know i'll be buying other suspension goodies..
any one experienced helping would be greatly appreciated!!
slipnfall
Car: '06 D40
Yeah I replaced quite a few things.
-Both the front and rear OEM upper mounts. The rear's aren't made up of much, but they aren't expensive(and I'm glad I did because I broke a stud removing them).
-Front strut mount seals(gasket)
-OEM front dust boots. Aftermarket rears.
-NISMO Rear upper and lower strut insulators
Total came to about $180 shipped, from http://www.midwaypartsteam.com
