other 5 lug nissan wheels on a s14? photoshop also requested
shift_jin
Car: 2003 Nissan Sentra SER Spec V
I had thought that the altima ser or the sentra ser wheel would look good on my car. the altima is an 18x8 with a 225/45 and the sentra ser is a 17x7 with 225/45. i do believe the altima's rims are also forged so maybe lighter than the sentra wheel (sentra wheel 21 lbs.)
I have plans to put some decent pwr to the ground therefor I thought that the altima ser wheel would be the best deciesion and also come in bronze or gunmetal.
I don't even know if they will fit (offset and tires size)
if anybody can photoshop these wheels on my s14 i would appreciate it
18x8 altima se-r wheel
17x7 b16 sentra se-r wheel
tramp_drift240
Car: 1992 240sx SE Coupe
fwd offsets are not cool.
shift_jin
tru but alot of 240s rock the b15 sentra ser wheels. i guess it's back to the drawing board. Thanks.
tramp_drift240
i havent seen a lot with sentra wheels. normally when its time to upgrade wheels, they actually upgrade wheels. not just get other OEM wheels to stick on.
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
here are the b15 wheels on my buddies red hatch and my old hatch. ya fwd offsets do suck, but if u had to pick, id go with the altima ones
tramp_drift240
yes, black piggy. very nice.
spooled240
Car: kouki s14
tramp_drift240 wrote:i havent seen a lot with sentra wheels. normally when its time to upgrade wheels, they actually upgrade wheels. not just get other OEM wheels to stick on.
not true, many 240 owners get OEM 300zx,350z,g35,etc wheels because they are taller and usually way wider than our stock 15x6's *knock on wood
To the OP, I would suggest 350z or g35 wheels, they are pretty wide and the 17's can be had for really cheap while not being a bad looking wheel.
irax
Car: VQ35DER Powered S14.3
sooo hawt G35 18's
just make sure you get COUPE g35 wheels no matter which one, the sedan wheels look almost exactly the same but are more narrow and more shallow on the offset. either way, be sure to get at least a 15mm bolt on spacer to make sure it will clear coilovers and z brakes.
spooled240
Car: kouki s14
^i love those wheels
