its my final btw
1) describe in detail the difference between SRAM DRAM DDR SDRAM and RIMM iclude specifics about speed bus width data cycles clock and bandwith ect.
2)Diagram how you can tell the difference between a typical 184 pin DDR DIMM module and a typical 168 pin SDRAM DIMM module
3) Describe and diagram each of the following types of memory; conventional, upper, expanded, extended and high
4) describe the secifications of each of the following ATA standards; ATA-1 ATA-2 ATA-3 ATA-4 ATA-5 & ATA-6
5) describe the ATA-IDE drive settings that you can use in a PC today, include when you would be best served using each different configuratiion (IE. Master, Slave, Ect..)
6) why is the standard CHS Bios hardware limit 528.5MB?
7) Why is the ATA-5 interface hard drive limit 136.9GB
8) describe the primary components of the head disk assemble and their functions.
9)describe the logical components of a hard drive (cylinders, heads, sectors, tracks, clusters, allocation units)
10) what does low levle formatting do to a hard drive.
11) what does partitioning do to a hard drive?
12) what does high level formatting do to a hard drive?
13) describe how optical storage is diffrent than magnetic storage
14) why is a pit a raised bump?
15)what is the difference between CLV and CAV?
16)What is important to remember if you are setting up a dual boot configuration on a PC?
17)Define the following terms; resolution, dot pitch, refresh rate, vertical scan rate, horizontal scan rate, pixal, non-interlaced.
