tiuse wrote: After running their diagnostics computer code that came up is P505 dealing with the Idile Control Valve.I had ICV changed and the problem was not solved. The dealer then said they have to do the following:
Vehicle needs Idle Air Control motor($395) andpossible on-board computer($1035). Upper intakemanifold is leaking and must be replaced($965).Engine air flow meter is defective($225). After newparts are installed, a vehicle software update must beperformed($99).
Time to fire your dealer.
They replaced your IACV, after telling you that was the problem, and it didn't solve the problem.
Tell them you want your old IACV back then.
Looks like they're stabbing in the dark. An ECU can be found for much less than that, and a "leaking intake manuifold" is re-sealed, not replaced (idiots).
If the MAF was defective, why didn't they tell you that in the first place? I may have a new OEM MAF I'd sell for cheaper...
Software update? They mean resetting the ECU?
Which dealer is this? I'd like to see their Service Advisor come on here and defend his vague and erroneous assessment.
