os giken twin plate clutch cover
StricNyne
ok so i am gunna be installing my fw, clutch and trans tonight so i am getting everything rdy, i have the specs on the flywheel to block, but i cant find the specs on the covers allen bolts. its like a pressed peice of steel with 30 allen key bolts how much should i torque them down
StricNyne
i can take pics of this tonight also !!!
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
good and tight. I dont think there is a spec for these bolts. If there is I dont speak Jap so it going to be hard to find it. I have the same clutch in both my rb swaps now. I just always hand tighten with a ratchet till there tight.
StricNyne
do u have a diagram for how the plates should be installed ?
gawdzilla
Car: none
sounds like you are strugglign big time...
the cover isn't much torque.. the bolts are small. probbly 12-15 ft-lbs. i think that was the spec for the exedy cover.
for a twin plate it will be flywheel, clutch, sandwich flywheel, clutch, cover. align it all with the clutch alignment tool and make sure the sandwich flywheel and cover are BOTH in the right position WRT the main flywheel, otherwise your clutch assembly wont be balanced.
StricNyne
hahah whats WRT position ? does it matter which side clutch disc is on it looksd like one side sticks out more than the other and its not labeled
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
IIRC the flat side faces towards the Flywheel.
garage-c
Car: RB25DET powered S14a
There is an OS Giken twin install writeup w/ pictures on zeroyon.com. Check it out...
StricNyne
yummy thnx !! aww man garage i owe u man !!! awesome write up, with this i should have motor in car TODAY W00t although it wont be running anytime soon, gettin that motor in car is a HUGE morale boost
gawdzilla
Car: none
WRT = with respect to
the zeroyon install says to offset the sandwich flywheel from the main flywheel.. that is strange. on the exedy you have to line them up. either way, there should be a mark on the outside of the entire assembly which indicates how they are supposed to line up.
StricNyne
pilot bearing wouldnt go in..... gunna have to prolly get an oem one SUCKS !!!!
