OS GIKEN RACING TRANSMISSION
leekor12
Car: 1991 maroon 240sx, 1993 white civic hatchback w/ gsr both for sell
this is the setup.
engine fresh rod and main bearing new piston rings new head gasket exedy stage 1 clutch fidanza ltw flywheel new water pump New radiator new thermastat OS GIKEN RACING TRANSMISSION (for sr but swapped bell housing) all engine parts are replaced with oem nissan parts AND I KNOW I AM FORGETTING A WHOLE LOT.
SUSPENSION KYB 6 WAY GAS ADJUSTABLE SHOCKS eibach lowering springs takata racing collars megan racing adjustable tie rods and other various beed replaced as well. brand new brake pads and rotors as well (put on yesterday. )
the transmission sounds like its grinding in gears, and is really loud. is it suppose to be like that? thank in advance.
leekor12
bump
MastaYu
Car: 92 Nissan 240SX SE HB
racing trannys do make slot of noise because of the shape of the gears.
crackler
Car: ZOMG JDM TYT3
Have you tried contacting the manufacture directly??? A phone call can go a long way.
PapaBurgundy
Car: 1991 240SX coupe SE CA18DET. 99 Dodge 2500 Cummins TURBO DIESEL 5spd.
Most serious racing transmissions have straight (dog cut) gears and possibly no syncros both of which make it much louder.
