nsanesrt wrote:1) so what kind of fpr are you runnin ..
2) could you run the sr rail and fpr...
3) ...without having to actually purchase a wideband
1) It's a B&M FPR kit that's meant for a Honda Accord IIRC...you cut the top off your stock regulator, and stick this sucker on. Thing is, you have to get creative and make a bracket b/c the FPR will not fit in the stock location like this...it's too tall. You have to rotate it so it fits...
2) No. And why would you want to? There's no advantage of the SR rail over the KA rail...and the injector spacing is not a match. And, the FPRs are identical...just a simple 1:1 Nissan FPR.
3) Too bad. You'll need to either buy a wideband, or get it on the dyno and verify the A/Fs are OK for boost. If not, you'll be replacing the motor.
- Brian
