ccsteve »
https://forums.nicoclub.com/ccsteve-u16641.html
Mon May 24, 2004 8:51 am
I bought the front and rear but ended up selling them before putting them on. The kit comes more complete than the whiteline and is half the price of the Cusco. the front is the same diameter as stock but it isnt hollow. I compared them side by side, there is a significant weight difference between the 2 but the ST is significantly stiffer. I personally wouldn't pass up ST swaybars, you cant beat 260 for a set. Be warned though, you need the rear bolts where it mounts, the kit comes with full mounting hardware for the front but the rear requires the stock bolts for the frame mounting. I was SOL because I have a base model, so no rear sway bar. Took me a week to find someone with the correct grade bolt and thread to fit. Ended up going to nissan. They charge 8 bucks per bolt here in Central Florida.
