hamsterball »
https://forums.nicoclub.com/hamsterball-u17566.html
Tue Jul 13, 2004 7:56 am
Well, you're getting an S14 SR20DET. That's not really too old.
But, if you want to keep it running normally and not risk any failures, just do basic maintenance.
You don't need a downpipe generally, but your stock downpipe from your KA won't work with the SR, so in this case you'll have to get one:
-Stock SR downpipe, or aftermarket.
You'll also want to take care of some other things that will keep it safe.
-Water Pump (I suggest getting an aftermarket one, such as JUN, because the stock Water Pump isn't designed to cool that well.)
- Oil Pump- Factory Nissan Belts (unless if the ones in your motor set are fine)
- Radiator (as mentioned above)
-And of course, Oil, Coolant, and transmission fluid that you will put when you install your swap.
After you have those, then you can move on to improving performance.
Such as..-Front Mount Intercooler (needed for running higher boost)- Fuel Pump- Z32 MAF
etc..
And if you only have $1,000 saved up for a swap... I don't suggest trying to get one..you will need more to buy the swap.. unless if you are planning on using a credit card (yikes)
