180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Jan 15, 2004 12:19 pm
Yeah I've heard them in action before. I was at a local shop and they were showing them off to me. The silencers do make it quieter to normal, but then there's not too much of a point to use the exhaust then as it'll change the effective open diameter, probably close to stock. The N1 duals aren't too loud. They've got a deep tone at low RPM, but otherwise streetable compared to the DD and the Spec D. Just that people don't seem to like them for the weight and want something a bit more showy. In terms of what's quieter, I'd probably have to say the N1 dual. I didn't get them side by side, but from what I can remember, that was the case.
The Spec D like most exhausts are stealable because of the rubber hangers. The rubber hangers can be cut off with razor blades as you cut the hanger where the exhaust's metal hangers poke into. Then there are just two bolts that can be reached from the side if you try to slide in from under the car from the rear. They can steal the muffler section, not the full catback.
The 2" drop can be an issue if you're not careful about the way you go up the ramp. I usually go up from my passenger side front to the driver side front, and continue to do that kind of crab walk up a steet incline or decline.
