Soulja »
https://forums.nicoclub.com/soulja-u11149.html
Sat May 29, 2004 5:22 pm
Well, those bushings are mostly useless to you. Your sway bars should have come with poly bushings, and the bars are a different size than stock anyway. If your coilovers have pillowball mounts, your not going to use the strut rod bushings. The only thing you would use are the control arm bushings, and by the way its described, I can't be sure if its LCA bushings, or t/c rod bushings. The tie rod boots are pretty much useless, unless your rubber ones are cracked and not holding grease anymore. You would be better off returning the whole set and getting a set of t/c rods (I like the dgtrials ones) or a set of tie rods, like tien.
