Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Sat Dec 06, 2008 4:05 pm
You need to check your timing with a timing light.
On the next step disconnect your oil return hose from the oil pan to where its just dumping to a drain bucket, and plug your oil return nipple on the oil pan.
Start it up for about 15 seconds if you dont see oil coming from there you have a clog in the turbine center section, if you remove the oil feed line, and dont have oil, coming from it after you start it up again for an other 15 seconds, keep going back untill you find oil coming out.
Have someone in the car to start the engine and someone, or yourself looking at the lines so you can kill the car.
Also, do this with the engine cold.
