Options for Rod Bearings. . .
tonkajuris
I have a knock on the #4 Cylinder at 2500 -3200 rpm. I can retard/advance the timing and this seems to move the knock rpm range up and down. I have researched threads and I seem to think it is a piston rod bearing. Also have read warnings that engine is about to sieze.
Anyone know how much it would/should cost to fix the #4 cylinder rod bearings on KA24E? I have 89 fastback se.
Any chance this can be done by avg mechanic?
Thanks for the help
tamungas
Car: 1989 240 hatch
dude i have a 89 hatch and im having the exact same problem..so i will be watching this thread... good luck man.
250sx
just wonderin, how did you know it was from #4?
TheOne
Car: 93 240sx FB
there could be many reasons for the knocking, it could also be the camshaft not gettin enough oil(clogged up oil pump).
