joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Tue Jul 06, 2010 11:17 am
They must have changed it from the last coupe...
The 35 series tires will not cause a more jarring ride, if anything, it will be smoother. The only negative is that you may have more road noise due to the increased contact patch of the wider tire. This is more dependent on the tire used though. Both the Yokohama S-Drives and the Toyo Proxies were quieter than the OEM bridgestones. The advantage of staggered rims is the drive wheels are wider for traction purposes. It's all about the contact patch...
