Optimal T25 KA-T ic piping diameter size?
Matej
So I've looked into what's available, and it seems that the most common ic piping diameters are 2.25", 2.5", and 3". Which one would work the best with a T25 on a KA24DET? I'm not planning on making crazy power, I'd probably run it at around 5 psi, if that matters.Thanks for any info.
lrb_2000
Car: '91 Nissan KA-T hatch
do 2" hot pipe, and 2.5" cold pipe.
WDRacing
With that tiny turbo and low boost, 2" all around will save you money and work just fine. Your best bet may be to go with a Ebay kit though. They seem to be pretty decent for the money.
WD
WDRacing
You'll never be able to pice a kit together and beat these prices...
FMIC Kit $110
FMIC Kit $145
FMIC Kit $156
nissanfanatic
Car: 1992 Nissan 240sx SE
2.25"
2" will reach the 300ft/sec intake air velocity boundary at 250whp..
WDRacing
With a T25 he'll never see over 250...
Jookmasta
i think 2.25 at the least, but if it was me 2.5" all around. why not go with the bigger piping if the cost difference is minimal. will leave room for when u upgrade ur turbo............u might say u won't but u will, we all do............
WDRacing
Well, the question was what pipe for a T25. To upgrade you'd need EVERYTHING replaced. So rather then talk him out of 2" piping you should talk him out of a T25 in general...
WD
WDRacing
Anytime man...
hannibal
Car: Red Line to Glenmont
In Maximum Boost, theres a formula for IC piping size based on airflow. Unfortunately, my copy is packed away in a box somewhere...
Jookmasta
tis tru he should be using a bigger turbo but gotta prevent further mistakes right? lol. j/k. 2.5" all around. u'll thank me later
Chezedik
Car: 1991 Nissan 240sx
about as big around as a quarter... Or you could just buy one of the preassembled kits that are based on the Greddy kit for the SR, seems like the easiest, safest, and best performing option. But whatever.
Tech12
Car: 91 240sx Super Hicas
WDRacing wrote:Well, the question was what pipe for a T25. To upgrade you'd need EVERYTHING replaced. So rather then talk him out of 2" piping you should talk him out of a T25 in general...
WD
Really? I figured you' just have to fab up a new hot side.
WDRacing
I meant to upgrade turbo's, sorry I didn't make that clear. The T25 is very small for a KA24. So the boost level you can run is very small. The T3 is the smallest I'd ever recommend to anyone unless they are going for a bare bones 5-6 psi kit. In which case a FMU and maybe not even FMIC is all you'll ever need.
WD
silnismo
Chezedik wrote:about as big around as a quarter... Or you could just buy one of the preassembled kits that are based on the Greddy kit for the SR, seems like the easiest, safest, and best performing option. But whatever.
am with him, why not use stock SR intercooler piping or, FMIC made for SRs.alot easier and also safest.
