Problem is that with the main harness taken out, it's about $1500 for harness at least and then not sure what else is wrong/fried until I do it all, so maybe even more money into it.biggie wrote:Seems like you could replace the harness and make more money by selling it as a whole and running.
The seats will be a little of a pain to get in the Vert. Not too much suspension that can be used, could use the rear 5-lug hubs to go along with full brake system (just need front 5-lug hubs).
I thought I could use the rear suspension, am I wrong?
IIRC, you will need sleeves for the bolts cuz hole on the spindle is slightly bigger on s14's.Hijacker wrote:set of S14 spindles/hubs. The front Z suspension is incompatable with the S-chassis suspension, so you'll be SOL on swapping that in.
If I part it out I will post in our forum, but first I will ask if anyone in the Z forum wants the entire thing. If that doesn't work I will post in both forums.I knew about the front suspension, I have the entire Coleman write up, but I may do the hubs for S13 instead, as it will definately be less hassle.Thanks guys, my ideas for this is right now to stay low key with stock CA18DET that I got from dee. I got a good camera for Christmas, so pics will start to be posted.Hijacker wrote:If you do end up parting out the Z, what would you want to part ways with the airflow meter? I'll be in the market for one here in the near future.
Should be able to.nomadlife wrote:hey I forgot, can I use the diff and shafts, it has a good vlsd?
Sorry this is a 2+2. Guess that nails it, I'll strip her.biggie wrote:And for the Ebrake cable, you'll probably need a Z32 2+2 cable, the regular Z32 is a bit too short.
