PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sun Jan 14, 2007 5:44 am
"Turbos" aren't set for a PSI (other than their efficiency range), Wastegates are set for the intake PSI. They determine this by the spring rate inside them. Basically, it works like this. There is a Diaphram that has air pressure on one side, and spring pressure on the other. When the 2 equal each other, this diaphram opens a valve on the wastegate, allowing exhaust to bypass the turbine, limiting the ammount of pressure/flow it makes. It does not matter if the wastegate is internal or external, you can still control it with a boost controler. What a boost controller does, is regulate down the pressure going to the wastegate. The wastegate might have an 8psi spring in it, so the boost controller does not let the pressure that the wastegate sees reach 8 PSI until the pressure on the other side of the boost controller reaches a certain point (whatever you set it at).
That being said, it is impossible to regulate below what a wastegate is set at. ie, If you have an 8psi spring, it is impossible for you to adjust it down to 6psi via your boost controller, you have to install another spring.That was pretty much the simple version.
Did that make sense to you?
