Grant@tirerack »
https://forums.nicoclub.com/grant-tirerack-u8792.html
Mon Jul 28, 2003 4:36 pm
That tire size should work fine on most of those cars. It doesn't look like you have lowered the car so that should fit fine. We always put the smallest tire size on the web so folks don't get carried away. The Conti Extreme Contact is a very good value for an all season. They are getting rave reviews on our website from customers but they are still a very new tire (just look at the miles logged so far). Most of the customers reviewing them so far have not even had the tires on for more than a month or two at the most. I found them to be fairly good for ride comfort and noise (typical of Continental) but they are not as sticky as I would like. The tread design in the center is very open which should do well in Winter but it tends to make the tire squirm in transition. It is a bit soft when it comes to hard cornering or fast lane changes. You can actually feel the center blocks squirm a little before the shoulder blocks grab in a corner. It is a very nice entry-level Ultra-High-Performance Tire at a very good price. Think the Sumitomo HTR+ is a slightly better buy especally when it comes to handling. That would be my top pick. I found them to be much more stable and much better in steering response. They are also non-directional so you can cross rotate with them for better wear patterns. The Kazara is a very nice wheel. Low pressure cast, shot peened and heat treated, they are a very good O.E. quality wheel. The 17X7 is only 17.5lbs and comes in at under $130.00 ! You will be hearing a lot about this line of wheels. If you order online, please be sure to go through our link on this fourm or contact me directly at 1-877-522-8473 ext# 313 so the fourm gets credit for the refrence! Thanks!
