Opinions on rebuild/installation
Neejay
Rebuild parts:
88' Nissan Pulsar NX SEOxygen Sensor CA18ET 200sx Bosch 13276 $47.99Spark Plugs CA18ET* 200sx NGK PFR6A-11 $Varies x2PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99 Thermostat CA18DE Pulsar NX 491-180 $4.99Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89Water Pump** CA18DE Pulsar NX B150-1350 $33.99Upper Rad. Hose KA24DE 240SX L-564 $7.99Lower Rad. Hose KA24DE 240SX M-563 $7.39Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49Alt Belt 4pk855 $9.99PS Belt 4pk845 $8.99AC Belt 4pk840 $8.99Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all)Turbo outlet flange gasket 14445-26E00 (S13 all)Head gasket 11044-51E00 (CA18 all)Engine gasket kit 10101-56E25 (CA18DET)Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate piecesIntake manifold gasket 14035-53J10 (SR20 all)
Is that list decent enough for a slight rebuild? Should I at least throw in some piston rings? I'll have a shop do the install so installation price will probably be a *****.
Along with the swap, I'll be throwing in the following:
- Nismo Motor Mounts ($180.45 performancenissanparts.com- Walbro 255 fuel pump ($100 ebay)- A'PEXi Auto Timer ($100 ebay)- greddy o2 housing (sr20) ($205.01 Shipped - optionimports.com)- Greddy downpipe (sr20) (168.73 Shipped - optionimports.com)- Catco 3" Cat Converter (flanged for a 240sx) ($166.25 phase2motortrend.com)- Oil pressure, boost, egt gauges as well
Im trying to get EVERYTHING planned out, so I'll have a ballpark figure as to what amount to save up.
240DRFT
you might want to get a fuel pressure regulator to go with the new fuel pump
f s t caz
Car: VG30ET D21 Extended Cab Pickup
go ahead and throw rings/bearings in. Do it in the beginning, so you don't do it a few months later (le sigh) when something goes wrong.
ca18detizzle
where do you get rings / bearings? sorry to ask, i have never rebuilt a motor before but would like to know more information. thanks.
N.O. Accorderz
oil pump?
Neejay
OK, so fuel pressure regulator, piston rings/bearing, and oil pump. I can agree with those 3.
float_6969
yes
