Opinions on Radiator fans.
912.0turbo
Alright, I have two choices.1. Order a Permacool 14 inch fan from HT rated at 2750 cfm and wait a few days or 2. Go to a performance shop here and buy a 14 fan rated at the same cfm today for cheaper but not a permacool.This other shop is a pretty reputable shop( http://www.alamoperformance.com ) bunch of old school guys.Do you guys think that it matters?
Cyberkreig
Car: 1993 Nissan 240SX SR
I didnt like my permacool. I love my FAL. Then again people on this board will say the exact opposite..
to your question; How soon do you need your car running? HT is a nico sponsor. They are reputable. They are pricey. Does brand name matter to you? Would you rather deal with someone local?
Its really up to you but I think i'd trust a brand name fans cfm rating over an autozone fan.
912.0turbo
Yeah I have autozone fans and they SUCK!I have the car running, its my daily.The fans I would be buying would be some name brand but not sure what.These guys usually sell good stuff and I would like to get the fan today.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i'm gettin a permacool thru HT...teh only thing i'm worried bout is the fan shroud..mine is F-ed up...should i get a new one or is it no big deal?
912.0turbo
If its not horribly bad I think you should be ok.
vboyq
i have a permacool from heavy throttle, and in stop and go dirving if my fan's not on the car will start to overheat.. and when it is on i NEVER see it move past the second dash mark, it stays under the 1/4 mark ALL day long. So take that as you will, but i say my permacool is doin its job
encasemyheart
I'm looking to replace my stock clutch fan on my SR.
You guys recommend a 14" FAL or Permacool for this situation?
And, can I remove the shroud if I go electric? With it out it frees up sooo much space.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i just used the stock auxilary fan wired into a subaru temp switch in the crossover pipe.
works wonders
912.0turbo
Actually I decided to go with a real nice fan with a built in shroud.It has a 2850 cfm rating and it looks to be a real nice fan.The guy there says he has the exact same one on his car that has 700hp so ill check his out then decide.
