Where the passenger side lower control arm connects to the rear subframe got sheared up a bit. It's a U-shape, with the bolt going through the 2 sides. It's hard to tell in the pics below, but the top of it is sheared/bent back basically to the main subframe, ie: there's no cross support.
Can I just cut/bend it out of the way? Should I take the rear subframe off and have someone weld a new cross support? Should I get a new subframe? Otherwise, the meat of the subframe itself doesn't appear to be damaged.
1st Angle:
2nd Angle:
Good drivers side, for reference:
