Opinions on my headlight upgrade.
JJM158
Car: 2007 Infiniti M35 S
As I have not seen led halos on many M, I am interested in installing them on my car. Think it will add a great aesthetic look!
Below are some images of some halo ideas based of a few owners who went through with the project. Would like as many opinions as possible:). I will also planning on adding an led strip on headlight.
https://imgur.com/KyfuJcb- dark strip via turn signal
https://imgur.com/7R1NMnO
https://imgur.com/cePugRd
https://imgur.com/uyk6cC5
https://imgur.com/IYdKrGT
The one picture with 3 halos looks good however halo choice not so much.
Mine will be from the retrofit source- profile prism
Larz
Car: 2019 Q70-L RWD
I'm not a fan of halos. BMW started them way back in 2000 or 2001. Back then it was new and unique to the brand. But soon after everybody with composite headlight systems copied it. Now it seems like old tech. However, the M headlamp system looks good with them but only with two halos. Doing the small turn indicator and making 3 halos per side is a bit much. Have you considered doing just the low beam headlamp with a C shaped LED strip at the opposite end by the turn indicator - similar to the Chrysler 3-- and stop just short of the halo over the low beam projector. Imagine a single halo over the headlamp projector added to the design below
JJM158
i agree having 6 halos is a bit to much. i like your suggestion will think about that ! i kinda like the angled led strip look at night lol
my other ideas would be from the grey car
EniGmA1987
Car: '06 Infiniti M35 Sport
You can also do other things than Halos, like "iron man" style and "demon eye"
https://i.imgur.com/zFrjpCj.jpg
OneEighty does really good work, but is a bit expensive. They can get it all done very pro looking and help you through options that fit.
There was also a guy from years and years ago in the M facebook group who does headlights too. His prices are better and they look fine, but is not quite as pro looking as OneEighty does things.
OneEighty examples:
https://oneightynyc.com/wp-content/uplo ... 24x680.jpg
