4gotn1 »
https://forums.nicoclub.com/4gotn1-u25219.html
Thu Sep 15, 2005 6:44 pm
dude ur waaay over kill on the fuel injectors i know i have a heavily modded ka24e. im stiill on stock fuel injectors and it pulls hard. i dont have any problems with them. and if your going to spray. use a wet shot. its just a little safer than dry.
ive got header, 3in test pipe, 3in kyo cat back, asp underdrive, msd blaster 2, magnecore wires, ngk plugs, custom short ram intake, removed ac, removed scv's, removed emissions (including egr), exedy stage 1 clutch, short shifter, port matched head & manifolds, chipped ecu, nismo motor mounts, vlsd, walboro pump, z32 fuel filter, ground kit, adj fpr, msd 6al, electric fan (16 inc) moble 1 synth fluids, and some more i cant think of right now. its a pretty long list. but i have yet to need to upgrade the injectors. my car ripped almost everything i raced. dude trust me once you get a few mods done you will be amazed at it. you dont need to go all out on it. but i had to run 93 with my ecu mods. i wanted best performance possiable. my car was also gutted severly. i only had a drivers seat and dash/doorpanels in it. that was it. everything else was gone.
trust me. u dont need all the added fuel yet. and i kept power steering too. its made it easy to turn with the 235's i ran on all 4 corners. but i would say get a lightned flywheel. my buddy has one with a act s/s clutch. his revs soo quick. hes also got nos. but i walk him when hes not spraying.
just get your basics down for now. i/h/e then i would suggest ignition after that.
