Although you don't NEED to, I would definatly reccomend it. I would also build a better baffle system around the pickup.TheColoradoQ wrote:Do I need to leave the windage try/baffle (in a modified form, for the pickup line)?
I would simply modify the stock pickup by lengthening it.TheColoradoQ wrote:What is my best option for the pickup line? It will have to be lengthend to reach the new rear sump location. Completely new line? Splice in a section to lengthen it? What are your ideas?
I think another 1-2Qt should be plenty. You might consider some work to the crank that would allow it to flow more oil, especially to the #3 main bearings. They're imfamous for lacking flow and wearing out first.TheColoradoQ wrote:While I'm about it, I'm planning to increase the oil capacity. How much is reasonable? And are there any other oiling system issues that I can address while I'm at it?
Yea. In that second pic, the front is on the right. My problem is that having the sump on the front interferes with my crossmember.pulsar gtr wrote:Are you trying to move the deap end of the oil pan to the opposite side, becuase I just looked at some pics of a rwd oil pan and it looks the same as the fwd.
very good info thereUK-SRi wrote:The reason number three bearing gets more wear is because of the firing sequence and lean running on 3 or 4 piston. it is actually shaking more than the other main bearings. You just need slighty more clearance on that bearing than the others and use a federal mogul copper backed babbit as opposed to the nissan aluminium backed babbit bearings.
If you look at the inlet plenum on the later Transverse SR20's you will see that the 3 and 4 intakes are moved away from each other to try and reduce this problem.
Mike
So is a "babbit" a bearing then?UK-SRi wrote:The reason number three bearing gets more wear is because of the firing sequence and lean running on 3 or 4 piston. it is actually shaking more than the other main bearings. You just need slighty more clearance on that bearing than the others and use a federal mogul copper backed babbit as opposed to the nissan aluminium backed babbit bearings.
Mike
